« Back to project details
Installation v2 - My private notes ;)
10/01/2021 at 21:04 • 0 commentsMy private notes ;)
My steps:
Write image: 2021-05-07-raspios-buster-armhf-lite.img
copy to boot:
empty file ssh
wpa_supplicant.conf
country=SK ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="mynetwork" psk="mykey" }
add in to config.txt
[all] hdmi_group=2 hdmi_mode=87 hdmi_cvt=320 240 60 1 0 0 0 hdmi_force_hotplug=1 dtparam=audio=on start_x=0 dtoverlay=audremap,pins_18_19 dtparam=i2s=on dtparam=spi=off
display IP address
ifconfig
via ssh
Login: pi
password: raspberry$ sudo raspi-config
SET AUDIO > headphones
boot console autologin piDISPLAY SETUP
sudo apt-get update sudo apt-get install cmake sudo apt-get install git cd ~ git clone https://github.com/bobricius/fbcp-ili9341.git cd fbcp-ili9341 cd fbcp-ili9341/build rm -r * cmake -DST7789VW=ON -DGPIO_TFT_DATA_CONTROL=25 -DGPIO_TFT_RESET_PIN=27 -DSTATISTICS=0 -DSPI_BUS_CLOCK_DIVISOR=6 -DUSE_DMA_TRANSFERS=OFF -DDISPLAY_ROTATE_180_DEGREES=ON .. make -j sudo ./fbcp-ili9341
Extra toys
sudo apt-get install mc sudo apt-get install w3m sudo apt-get install mpg123
KEYBOARD SETUP
cd ~ git clone https://github.com/bobricius/gpiokeyboard.git pip3 install python-uinput
For autorun on startup put this line before
exit 0
in yoursudo nano /etc/rc.local
sudo /home/pi/fbcp-ili9341/build/fbcp-ili9341 & sudo modprobe -i uinput & sudo python3 /home/pi/gpiokeyboard/gpiokeyboard.py & sudo setfont /usr/share/consolefonts/Lat2-Terminus20x10.psf.gz &
