Credit to Adafruit for initial design => https://learn.adafruit.com/permaproto-feather-case
A universal enclosure designed for quick deployment
Universal_case_assembly.SLDASMsldasm - 127.10 kB - 01/18/2021 at 16:25 |
Universal_case_base.SLDPRTsldprt - 222.23 kB - 01/18/2021 at 16:25 |
Universal_case_lid.SLDPRTsldprt - 149.89 kB - 01/18/2021 at 16:25 |
Universal_case_sides.SLDPRTsldprt - 114.68 kB - 01/18/2021 at 16:25 |
DIMENSIONS.txtplain - 454.00 bytes - 01/18/2021 at 16:25 |
This directory contains the necessary components to build a custom PCB enclosure
Update ~/DIMENSIONS with correct equations for your PCB
Rebuild ~/Universal_case_assembly
export the three components as .STL
Import and slice the .STL components
Print and enjoy!
If there is a demand for it I will attempt to port this to other CAD clients.
