Hackaday.io Hackaday.io
Sign up Log in
Simple ESP32 SD audio player (internal DAC / PDM)
Discrete component audio out
ronaldRonald
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.9k views
1 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
3.9k
1
0
0
Team (1)
  • ronaldRonald
Join this project's team
researching project
This project was created on 01/10/2021 and last updated 5 years ago.
Description
Looking for a simple (as in: using only additional components that are in my stock) way to play audio, I found not what I wanted. Trying to gather info here.
Project Logs
Collapse
  • Gathering info - playing sound
    Ronald • 01/10/2021 at 14:14 • 0 comments
    WAV library: https://www.xtronical.com/basics/audio/digitised-speech-sound-esp32-playing-wavs/
    A github project that probably plays a wav file: https://github.com/LilyGO/TTGO-T8-ESP32
    A micropython project playing WAV (though I'm quite sure I read somewhere that the internal DAC wasn't yet supported on micropyton): https://m5stack.hackster.io/lukasmaximus89/play-wav-files-on-your-m5stack-3bee7e
    internal *ADC* code: https://github.com/espressif/esp-idf/commit/2fceec4d858c62a489496678c765ae1a2d68645c
  • Gathering info - PDM output
    Ronald • 01/10/2021 at 13:38 • 0 comments
    Well, I started typing, and then lost everything.
    There are some projects on hackaday that have simple audio output (and even video), but none of them connects to a speaker directly.
    This is how I connected my SD card:
    https://github.com/espressif/arduino-esp32/tree/master/libraries/SD
    There's this project that does PDM: https://github.com/karawin/Ka-Radio32. It tells to connect a speaker to GPIO 25 for PDM/internal DAC, but I think that would way exceed the 12 mA of max output current.
    I found a 40xx/74xx logic buffer circuit for PDM sound somewhere (lost the link...), and a mention that a MOSFET would be a good idea. Somewhere else I found adding a 100 uF / 47 uF capacitor between output and speaker should do the trick.
    There's this video:https://www.youtube.com/watch?v=oCmfpJNDPn8 that shows an ESP32 with audio out over PDM
    This shows something about how to use PDM: https://github.com/earlephilhower/ESP8266Audio/issues/138 (and also notes that for a long time, PDM hasn't worked)
    This project also mentions PDM: https://github.com/MrBuddyCasino/ESP32_MP3_Decoder. The source seems based on Ka-Radio32 - or probably the other way around.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Pierre-Loup M. wrote 01/11/2021 at 10:23 • point
I'm using this library on an ongoing project : https://github.com/earlephilhower/ESP8266Audio
The library is easy to use and quite versatile, although there are some "bugs".
If using an esp32 is not mandatory, then there is Teensy from JPRC, and their powerfull audio lib.
A buttonless toy that encourages kids to interact rather than simply mashing buttons for stimulation.
Project Owner Contributor
NFC Fun - A Toy for Children with Sensory Needs
circuitmonsterCircuitMonster
An interactive, life-sized sculpture with embedded audio components that plays a story from the 1001 Nights when a person approaches.
The moon upon its fourteenth night
pansee-attaPansee Atta
Analog & DSP
Audio FX | Effects
gintaras-valatkaGintaras Valatka
In this project we will make our own audio player with esp 32. This project is a simple project to test a voice output from esp 32.
ESP 32 Based Audio Player
electronicsworkshopselectronicsworkshops
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Simple ESP32 SD audio player (internal DAC / PDM)", please tell us the reason.
Send message
Remove Member
