Description : Face Follow Mobilephone Turret 1.0
A 2DOF phonestand with raspberry Pi camera for facetrackning. When position of face change the axis move accordingly to adjust stand, so that the face remains in the middle of the videochat window. It should also be possible to control the turret via a remote control Joystick.
LCD should be mounted to be able to se face follow turret status.
Project update: 210101
- Old solution with servo motor and B-axis is going to be improved with bearing and stepper motor for smooth operation.
A stepper motor of type : Y 28BYJ-48is going to be used , and new housing for raspberry and electronics is being constructed.
Description : Face Follow Phone Cam Turret 2.0.1
- Replace servo motor on B-axis for smother operation
- Bearing for B-axis
- Housing for electronics
- Homing sensor for B-axis
- New design for phone stand construction
