Start of project :
3D CAD and Printing parts.
Turret consists of several parts that should make it easy upgrade turret as new improvements are made during development.
- Lower turntable house
- Lid for connecting servo to the upper part of B-Axis
Servo ( C-Axis) plate with hinge
Adaptor hinge upper part
Phoneholder , with camera attachment
Camera arm mount , and lids
First all, parts prints are made with medium quality as further improvements will be done. First prove theory then make improvements as project evolves.
Issues with primary construction:
I have som issues with the lower part (B-Axis) that should have a stepper motor in the feature. For now i use the small servos instead. Movement is limited by the ribbon cable connected to the raspberry PI. Approx 180 degrees of freedom at present time
övre delen av facefollow cam cap börjar ta form.
