The very first proof of concept worked, and then some! I managed to cut some foam board with a makeshift foam cutter (Add one part ATX Power Supply, one part Nichrome Wire, one part wood, and a sprinkle of various metal hardware), and fit two 40mm EDFs onto the part. The LiPo battery and HTC One S were put on there to make sure it would actually list most of the weight.
This test was with three sheets of 1/2" Foam Board, without any type of skirt, and I didn't even need to hit full throttle to get the board to hover. This is very promising since I think performance will only improve once I actually direct the air with some sort of chamber. There was a lot of air leaking through the sides of the craft, which I hope to correct with some sort of chaimber.
