PasswordVault on Tindie.com
01/27/2021 at 20:07 • 0 commentsHi,
PasswordVault can now be bought on Tindie. You receive a Wio Terminal with preinstalled PasswordVault software.
Of course, you can still simply install the PasswordVault open source software on a Wio Terminal you already own. This is even easier now that the software is distributed as UF2 file.
Just download the UF2 file from the latest release of our Github repository and simply drag it to the Arduino drive. The software starts automatically. Now, of course, you need to copy your passwords to a micro SD card. There are instructions and a python script on Github,
I look forward to your feedback :)
-- Olav
v1.10
01/24/2021 at 22:22 • 0 commentsRelease 1.10 is the first release we provide as simple to install UF2 file. To install, pull the reset switch on the left side of the Wio Terminal twice. A new drive named ARDUINO will appear in your finder / explorer. Just drag the file passwordvault-v1.10.uf2 there to install it.The user features are identical to v1.8 which are described in our wiki.
Olav Schettler
