I did a bit of a hack in the circuit. I need to use voltage dividers to measure the voltages on the individual cells, but instead of building 7 separate voltage dividers for all 7 cells, I split the divider, and added a multiplexer in the middle to switch between the different cells. In addition to making for a fairly simple circuit, it would've also allowed me to "switch off" the voltage dividers completely, so there wouldn't be any drain on the batteries. It seemed like a good idea, but the results were questionable.
The voltage divider and multiplexer part or the schematic
Measurements with only a single cell connectedTurns out that doesn't work. Why? Well, the multiplexer doesn't just switch between channels, there are also some diodes and other protection stuff, and that does some weird things at times.
What's the short term fix? Having 7 "full blown" voltage dividers. I wanted to try it on this PCB, so I did some funny air circuit fun.
ed things. For now at least. However, now, it actually uses power all the time, from the batteries. As it's a prototype, it's not that bad, and I can also scale up the resistances quite a bit, to reduce the power drain. That's a quite simple fix hopefully, and then we have a working node.
Longterm, I could use a different method of measuring, but that's for the future
I've been working on this for a while, but waited forever to get the PCBs made. Finally did, and also got the parts, and started soldering
There are a few SMD components which I put on first. Really have to get a new soldering iron, and practice my SMD soldering skills more.
All parts necessary for some initial testing in place. But turns out I couldn't flash it using the ISP connector, because the ground planes weren't connected properly.
The problem and the fix. Quite simple to fix in the next revision, but I should've totally seen that. And all the sudden, the ISP works as well.
