Ukarumpa clock
In remembrance of my Papua New Guinea visit
I used to live in Papua New Guinea in the town of Ukarumpa for the last 4 years and I only moved back to my home country recently. I thought of publishing the plans of this clock to celebrate the transition and the milestone of completing this time period.
Reason
As some of you probably saw in the description of my profile, I used to work years ago as a HW design Engineer for a multinational company and later I moved to Papua New Guinea. I've been working as a radio and maintenance Engineer there helping some aid organizations the development of the 3rd world countries. This month I returned from my exotic journey around the world and I thought of publishing the plans of this clock to celebrate this transition. I hope that the entire exercise of posting these schematics will help me overcome the reverse culture shock in a smoother way.
About the clock
The clock uses normal 7 segments LED displays and it will have 6 of them. This will allow for the possibility of displaying 24h format times with minutes and seconds. In addition to the seconds displays, it will have an incrementing bar graph consisting of 5 leds which will increase with the count of the tenths of seconds. So every 10 seconds another LED on this bar graph will turn on. The LED bar graph will be split in two sections. Three LEDs will be positioned between minutes and seconds, and two of them will be the dots ":" between hours and minutes. This will create an interesting light effect.
Scrolling messages
As many of my clocks, this one will display 5 scrolling messages every sharp hour:
1) missing Papua New Guinea
2) the land of unexpected
3) home of 839 distinct languages
4) best snorkeling experience
5) hike through the jungle
Other features of the clock
- RTC time with coin battery memory retention
- Precise time and easy to set
- Possibility of year, date and temperature display
- Leap year automatic change
- PWM display dimming function that can adjust with ambient light
- Back light
How it works
This clock uses the MSP430G2553 mcu as its brain. The software is written in C++ and I programmed it with the MSP430 launch pad and IAR Embedded Workbench. If you want to try to replicate this clock, I suggest you use the same programming environment for flashing the code into the device. Other platforms might use different compiling strategies and the resulting flashed size could differ from mine. The risks would be that the code might not fit into the flash memory or some of the timing sensitive delay loops inside the code might be affected by this.
hook.stl
3D file of the hook
Standard Tesselated Geometry - 27.43 kB - 01/31/2021 at 13:54
Download
Cronos_Ukarumpa_C1_backup.txt
Firmware
plain - 24.88 kB - 01/31/2021 at 13:53
Download
Gerbers Ukarumpa Clock.zip
All the gerbers for ordering this PCB
x-zip-compressed - 123.14 kB - 01/25/2021 at 14:01
Download
Wall clock Cronos_C1.dch
Schematic- open with DipTrace
dch - 413.21 kB - 01/25/2021 at 13:58
Download
Wall clock Cronos_C1.dip
Layout - to be opened with DipTrace
dip - 642.81 kB - 01/25/2021 at 13:58
Download
  • Communication with the RTC
    Marius Taciuc01/25/2021 at 15:03 0 comments
    I used my DSO oscilloscope to sample some of the communication packages between the RTC and the MCU. Here are some shots:
  • Using any type of 14mm LED display
    Marius Taciuc01/25/2021 at 14:57 0 comments
    You probably noticed from the schematic that each display is fitted with a half-bridge of transistors. This allows for installing both CC and CA displays on the motherboard. You just have to be careful not to populate both of them. If you use a Common Anode (CA) display, you will have to populate the high side driver transistor and vice versa.
    In my case I used CC displays and I populated the Qxxx_B side of the half bridges as seen in the image:
View all 2 project logs
  • 1
    Ordering PCBs
    I ordered my PCBs from PCBway.com
    If you want to replicate this project, just send them the provided gerber files and they can send you the PCBs through mail anywhere in the world. I've been working with them for a long time now and they proved to be very reliable and trustworthy.
    I will add a quick link to this project's page for ordering the PCBs in a smoother way. Just stay tuned for updates in the left side of the page.
  • 2
    Flashing the firmware
    Check the "Added firmware" log of my other project:
    https://hackaday.io/project/175830-cookie-jar-clock-of-passion
    I used exactly the same method and flashing port on this one. In fact, almost all of my MSP430 projects use the same standard, dongle and wires.
View all instructions
