Communication with the RTC
01/25/2021 at 15:03 • 0 commentsI used my DSO oscilloscope to sample some of the communication packages between the RTC and the MCU. Here are some shots:
Using any type of 14mm LED display
01/25/2021 at 14:57 • 0 commentsYou probably noticed from the schematic that each display is fitted with a half-bridge of transistors. This allows for installing both CC and CA displays on the motherboard. You just have to be careful not to populate both of them. If you use a Common Anode (CA) display, you will have to populate the high side driver transistor and vice versa.
In my case I used CC displays and I populated the Qxxx_B side of the half bridges as seen in the image:
Marius Taciuc
