• PIO (Programmable I/O) Part 1
    Uri Shaked • 06/05/2021 at 09:33 • 0 comments
    This week we started working on the PIO implementation:
    We also held a spontaneous stream where we created a test suite for the PIO instruction set, running it against the silicone rp2040:
    We'll continue hacking on the PIO this Tuesday.
  • MicroPython!!1
    Uri Shaked • 05/28/2021 at 09:05 • 0 comments
    In the last live stream episode, we implemented GPIO (+ Interrupts). But we also figured out that we're just a small step away from running MicroPython in the emulator.
    And so, yesterday I decided to go on a spontaneous live stream, trying to implement UART RX in order to close the gap and get MicroPython running!
    Spoiler: We did it! You can now run MicroPython with RP2040js. I also uploaded a quick proof-of-concept to Wokwi. It works well, though it's not very polished at the moment:
    https://wokwi.com/arduino/projects/299738191162769933
    After opening the link, don't click the green "Play" button. Instead, follow the instructions in the comment at the top of the sketch file. Enjoy!!
  • RP2040 Timer Alarms + GPIO
    Uri Shaked • 05/20/2021 at 12:11 • 0 comments
    We spent the last coding live stream implementing the Timer Alarms for the Raspberry Pi Pico:
    We also changed our Peripheral abstraction to handle Atomic I/O Register Writes and started working on the GPIO peripheral (refactoring SIO along the way).
    To be continued....
  • gdbdiff bug squashing!
    Uri Shaked • 05/15/2021 at 12:36 • 0 comments
    gdbdiff is a fast and reliable way to check our instruction set implementation. It runs the same piece of code on both the physical Pi Pico (the silicone) and the emulated Pi Pico, instruction by instruction, and compares the CPU state after each instruction.
    We held a bug squashing session yesterday and spotted several instruction bugs thanks to gdbdiff. The gdbdiff part starts at hour 1:25:00  into the stream—
    gdbdiff works by using the GDB Remote Serial Protocol to debug the Pi Pico and the emulator. It has a client implementation of the protocol which connects to the RP2040 silicone through OpenOCD, and to the RP2040 emulator using the gdbserver stub.
    Thanks to gdbdiff, we were able to find and fix several bugs, mostly related to the Cortex-M0+ flags in the APSR register, and also an edge case in LSRS:
    The last issue in the list also caused a funny behavior of printf() when printing numbers from the Arduino Mbed OS core.
    Using gdbdiff proved to be a very efficient way to spot tricky bugs. Previous attempts to spot such bugs required hours of laborious debugging, and now we have a tool which automates the process.
    At this point, the emulator's instruction set is mostly ready. There are still some multi-core and interrupt-related instructions that we need to implement (e.g. SEV, WFI, WFE), but they shouldn't normally affect the code flow.
    We'll keep hacking on the emulator this Tuesday, adding Timer Alarms, GPIO, and maybe also the SIO divider. See you then!
  • Crazy Week! Systick, Instructions and Testing the Tests
    Uri Shaked • 05/11/2021 at 15:55 • 0 comments
    Whoa, this week had three(!) spontaneous live-streams, in addition to the usual weekly stream. It all started when we tried to get the official Arudino Core for the Pi Pico to blink a virtual LED:
    We started working on the implementation of SysTick, a timer built into the ARM Cortex Core, and ran into problems. So we did another live troubleshooting session:
    As we couldn't really figure out the problem, we decided to start tidying up the code and implementing all the missing instructions, in another spontaneous session:
    Finally, following a suggestion from Mike Wright on the YouTube channel and a GitHub discussion with Valerio, we decide to verify our unit tests against the actual RP2040 silicone. We also set up ESLint, discovering a few small but significant bugs in our code:
    Well, it's definitely been a crazy week. See you in the next stream today!
  • Compiling Arduino Mbed OS Core for the Raspberry Pi Pico in Debug Mode
    Uri Shaked • 05/09/2021 at 17:39 • 0 comments
    In one of the recent live streams, we tried to debug a program compiled with the official Arduino Core for the Pi Pico.
    However, debugging it proved difficult: the Arduino Core produces programs without debugging info. In addition, it's based on Mbed OS, an embedded operating system for ARM Cortex-M processors. Mbed OS adds another layer of complexity: it manages tasks and threads, and does a lot of work behind the scenes even for a simple Blink program.
    Therefore, I decided to compile the Arduino Core for Pi Pico from scratch, and this this with debugging symbols. This log explains how I did it. If you want to follow it, you need an Ubuntu or Debian-based Linux system (for Windows users, WSL is also fine).
    1. Installing Dependencies
    Install the Mbed OS CLI. For Linux:
    sudo apt install python3 python3-pip git mercurial
    python3 -m pip install mbed-cli
    For other environments, check out the Mbed OS CLI documentation
    In addition, the Arduino Mbed OS core requires jq. Install it too:
    sudo apt install jq
    2. Get the source code
    git clone https://github.com/arduino/mbed-os arduino-mbed-os
    git clone https://github.com/arduino/ArduinoCore-mbed
    Note how we clone mbed-os from Arduino's GitHub. They have their own fork with patches specific for the Pi Pico. At the time of writing, they still haven't merged these patches upstream.
    3. Patch it
    Apply the following patch to the ArduinoCore-mbed. The patch enables debug build:
    diff --git a/mbed-os-to-arduino b/mbed-os-to-arduino
    index 902b0c5d..921c39a8 100755
    --- a/mbed-os-to-arduino
    +++ b/mbed-os-to-arduino
    @@ -130,6 +130,9 @@ mbed_compile () {
    PROFILE_FLAG=--profile="${PROFILE}"
    fi
    export PROFILE=-${PROFILE^^}
    + else
    + export PROFILE="-DEBUG"
    + PROFILE_FLAG="--profile=debug"
    fi
    4. Build it!
    cd arduino-mbed-os
    git checkout rp2040
    mbed deploy
    cd ../ArduinoCore-mbed
    ./mbed-os-to-arduino -r "`pwd`/../arduino-mbed-os" RASPBERRY_PI_PICO:RASPBERRY_PI_PICO
    You may be able to skip mbed deploy - I not sure if it's actually needed.
    If everything went well, you'll find the compiled library under ArduinoCore-mbed/variants/RASPBERRY_PI_PICO/libs/libmbed.a. The debug symbols make it pretty heavy - expect a 135MB file.
    You can copy this file over your existing libmbed.a in the Arduino directory, e.g.:
    cp  ArduinoCore-mbed/variants/RASPBERRY_PI_PICO/libs/libmbed.a ~/.arduino15/packages/arduino/hardware/mbed_rp2040/2.0.0/variants/RASPBERRY_PI_PICO/libs/libmbed.a
    The target path may vary depending on your system configuration and the version of the mbed_rp2040 core you have installed.
    Happy debugging! ;-)
  • Interrupt Controller
    Uri Shaked • 04/26/2021 at 09:30 • 0 comments
    We spent the last two episodes working on the Nested Vectored Interrupt Controller (NVIC), adding some more instructions (UXTH, MULS, REV), and working on the special register implementation (MRS / MSR / CSPID i / CPSIE i) instructions.
    We got Hello Serial to work, and started looking at running the Arduino Core for Pi Pico, based on Mbed OS, in the emulator.
    Along the way we also found how to make GDB much faster by disabling Nagle's algorithm in our gdbserver. Now debugging the emulator is so much more delightful!
    Interrupts, part 1:
    Interrupts, part 2:
    In the next episode, we will implement the SVC instruction, look at an interesting bug in our MULS implementation, and try to get the Arduino Core "blink" to work. See you tomorrow!
  • Alpha Release!
    Uri Shaked • 04/12/2021 at 10:09 • 0 comments
    Last week we released an alpha version of RP2040js to NPM, the JavaScript package manager. We spent the first hour of the stream tidying up the code, setting up the tooling and preparing the release.
    Then, in a sharp turn, we went back to working on the code: refactoring the peripherals, implementing narrow I/O register writes, adding a missing variant of the CMP instruction, and even creating the Timer peripheral.
    Our new goal is to get hello_serial to run. Unlike hello_uart, it uses a set of high-level APIs, including printf() and sleep_ms(). That's also the reason we needed the Timer:
    In the next episode, we'll keep working on the Timer, and probably also implement the Nested Vectored Interrupt Controller (NVIC), to let us fire interrupts from our virtual peripherals.
  • We did it!
    Uri Shaked • 04/02/2021 at 18:11 • 0 comments
    This week we managed to get a Pi Pico program to run start to end in our emulator!
    The happy moment happened just as the stream was about to conclude, about 2:29 hours into the stream. You can watch the full recording here:
    Or, if you want to try running hello_uart yourself and replicate our success, you can clone the repo and run the code:
    git clone https://github.com/wokwi/rp2040js
    npm install
    npm start 2>&1 | grep UART
    The "grep" part takes care of hiding all the debug prints we have in our code... 😜
    Alternatively, you can also run it in the Gitpod cloud. After launching the workspace simply copy the two npm commands above and paste them into the terminal. Enjoy!
    Next week, we are going to tidy up the code and publish a first alpha release of rp2040js to npm. So if you are reading this after April 6th and still want to run the hello_uart example, make sure to git checkout 175f616.
    So far we spent about 25 hours of coding to unlock our first milestone: running a basic program from start to end in the emulator! ðŸ”“
    The next live stream happens on Tuesday, and you'll be able to watch it here.
  • Disabling all Compiler Optimizations in the Pi Pico SDK
    Uri Shaked • 03/31/2021 at 11:58 • 0 comments
    During our last live-hacking session, we discovered the compiler optimizations were severely limiting our ability to debug the code in the emulator. Function inlining, code rearrangement and tail call optimizations made debugging with GDB much more challenging.
    After digging a bit in the Pico SDK's build system, we learned about a flag that disables all the compiler optimizations, PICO_DEOPTIMIZED_DEBUG.
    Here's the complete sequence of commands for building the Pico examples in debug mode and without any compiler optimizations:
    cd ~/pico/pico-examples/
    rm -rf build
    mkdir build
    cd build
    export PICO_SDK_PATH=../../pico-sdk
    cmake -DCMAKE_BUILD_TYPE=Debug -DPICO_DEOPTIMIZED_DEBUG=1 ..
    make -j4
    It is also possible to build just a specific example, by running the make -j4 command in a subdirectory of the build directory. e.g., to only build hello_uart, we'll first change the directory to uart/hello_uart:
    cd uart/hello_uart
    make -j4
