• 1
    3D Printing and Assembly
    All the parts are designed on Autodesk Inventor 2019. I provide the STL files. Printed on a Creality Ender-3 Pro,
    with BQ PETG. These are the CURA settings for all the parts printed:
    • * Layer Height: 0.2
    • * Wall Thickness: 0.8
    • * Top/Botton Thickness: 0.8
    • * Top Layers: 4
    • * Bottom Layers: 4
    • * Infill: 60%, Grid
    • * Printing temperature: 220 ºC
    • * Build plate temperature: 80 ºC
    • * Speed: 50 mm/s
    • * Cooling: Enable
    • * Fan Speed: 100%
    • * Enable supports: Everywhere
    • * Build Plate adhesion: None
    Note that all the parts are sturdy and the print time is about 3 hours for the plate. Let the printed print. Check
    that the nozzle in clean (run small batches) because the PETG is very sticky and stringy.
  • 2
    Mounting
    Levers
    First of all, mount the lever adapter into the levers. If you print your custom paddles, skip this step.
    Add the spring into the back, and glue it.
    Base Plate
    Insert the lever into the base plate, and pass the M4 screw as axis. Bolt it. Sand all the parts to get a
    smooth operation. Then, screw the cap tight. This part is the interface with the plate, and limits the
    travel of the lever. Screw the levers into the plate. You're done.
     Mounting on wheel base
    Put the plate in the wheel base, and place the reinforcements. Screw the big M6 screws in position, and tight
    it. I use some double tape to avoid any hold between reinforcement-cap and plate-wheelbase parts. Mount the
    wheel and check that nothings collides and the wheel moves freely and smooth. Now, we can mount the
    electronic components.
  • 3
    Fanatec Protocol
    Fanatec wheel bases use a internal protocol to talk with their devices, and does this interface using
    RJ12-6p6c electrical interface cables. I don't wanna break my wheel base, so I check the internet, and
    find this amazing post: how to [convert the Fanatec Shifter to USB](https://hackaday.io/project/171155-fanatec-clubsport-shifter-sq-v15-usb-adapter-diy)
    **Yin Zhong** does some amanzing reverse engineering and, with the of [this post](https://www.gtplanet.net/forum/threads/conversion-of-a-logitech-shifter-for-fanatec-wheelbase-compatibility-enabling-7th-gear-other-mods.384099/) and
    [this document](https://www.gtplanet.net/forum/attachments/conversion-of-a-logitech-shifter-for-fanatec-wheelbase-compatibility-by-b-spec-_-bob-dec-2018-pdf.787424/)
