Door Assembly
04/20/2022 at 18:17 • 0 commentsI just managed to finish another video about my FULLY 3D PRINTED #electricvehicle project. And finally I was able to test my ideas on a real part.
Looks like it holds quite well, I am very happy and proud.
It is just a 2 min. video. Hope you enjoy it. -
How to Glue PLA like a PRO
03/22/2022 at 12:33 • 0 commentsAfter a long stop in this project, I was able some weeks ago to retake it.
I finished the development of the chemical welding for the 3D printed parts. And it certainly works quite well.
If you are interested here is a video about it, make sure to see the end of the video... -
How the Jellybean3D was designed
02/23/2021 at 10:41 • 0 commentsHere are some details about how the Jellybean3D is designed:
- The intention was to use 3D printed components and parts as much as possible, so I decided to make an unibody vehicle in order to avoid the use of a metallic chassis to support the body.
- Although a vehicle like this could be made by many other different approaches, it is designed to be 3D printed.
- Given the strength limitations of the materials available for hobby printers I have been very cautious on the structural design. So I created 4 different levels of structures: eggy shape, internal ribs (like airplanes fuselages), reticular structural web created by the bondings, and internal mesoscale structure created by the infill in every part.
- The big parts, body and door were designed as whole parts and later strategically cut in order to:
- Get the most strength in the directions that are more needed and make them coincident with the XY printing plane.
- Avoiding or enforcing the cuts in determinate areas in order to strengthen or not weaken them.
- Taking in account the appropriate cut orientations and cut locations in order to avoid the use of supports when printing.
- Some parts like the knuckles and others, have been topology optimised.
- For the non printed parts and components I tried to use very easy to find materials or components.
- In order to make strong bondings between the parts I developed a chemical welding system, more info here: https://youtu.be/5LqmyYqS6-k
First printed parts
02/16/2021 at 20:43 • 0 commentsFirst parts just come out of the printer (door parts+), all looks good so far.
Next step post-processing and chemical welding. -
Video Blog (Part 4), Components
02/16/2021 at 20:37 • 0 commentsA list and info of principal components:
Video Blog (Part 3), 1/10 scale model
02/16/2021 at 20:03 • 0 comments1/10 scale model of the Jellybean3D.
I have created a 1/10 scale printable version. The printing files can be downloaded from here: https://www.prusaprinters.org/prints/47678 or here: https://www.thingiverse.com/thing:4669754
And assembly guide for this scale model is here: https://youtu.be/9_9_ydc-NO4
3D CAD document of 1/10 scale version: https://cad.onshape.com/documents/e88854e0f694e95508aed56c/w/c09b93324fe9abec278f257b/e/2b249be11dccc2a3ce46b4fe
Video Blog (Part 2), First tests parts
02/16/2021 at 19:27 • 0 commentsFirst printed parts tests and first final parts:
Video Blog (Part 1), Introduction
01/28/2021 at 22:03 • 0 commentsIntroduction to the project:
