As explain, edog will participate in the Eurobot cup.
To do so, I need to know the robot position in (x, y) on the table. But I can't use embedded lidar or using triangulation due to its small size and its limited capacity to carry heavy components.
So What I will attempt to do is using a beacon with a camera and estimate the position giving a video flux.
This beacon is composed with an NVIDIA Jetson Nano 2gb board, a TPLink Nano Router, a 7inch touchscreen and a DC converter to 5v and 5A. that allow to used 3s to 6s lipo to power up the sytem.
Here an exemple of the team ARIG Robotique (more infos here)
Step #1: original video
Step #2: Optical distortion usgin OpenCv in python
Step #3: projection in an orthonormal coordinate system
Gaultier Lecaillon
