All the stl files will be drop after the French Eurobot cup, the 1st June 2021.
here you can see all the part involves, Everything has been design for an easy build and easy printed without support needed.
Only 4 * M3 screw are needed for the frame ! 🔩
It makes edog very simple to build, so everyone can build his own easely
