A Home Info System (a.k.a Clock) Which displays the Time, Date, Humidity, Temperature, Barometric pressure and Moon Phase.
I finally got rid of the dvd player that was only used for the time it displayed (the player itself stopped working years ago). But that left a large empty space especially noticeable when ever I looked over for time based answers.
So I recently bought a Gixie clock that broke after a few hours so I decided to build a decent one myself.
One unit is build up from 8 stacked 45mm by 83.5mm laser-cut plates.
1 - 6 are 3.5mm plywood. 7 white acrylic 3mm. 8 smoke/grey acrylic 3mm.
1) Back. 2) Space for the wires. 3) Mounting plate for the Led breakout boards. 4) Alignment plate for the Led breakout boards. 5&6) light guides to direct the light. 7) diffusion/projection plate. 8) dimming plate.
