Y-distribution base
03/10/2021 at 16:18 • 0 commentsToday I posted a small article about a Y-distributor on Nerdiy.de. With the help of this distributor, a suction support can be distributed over two branches.
More Infos here:
Fume extraction hose
02/17/2021 at 19:40 • 0 commentsI added a small guide to build a fitting solder fume extraction hose. Please see the attached pictures. You can find the build instructions incl. stl files and more pictures here: https://nerdiy.de/en/howto-3d-druck-loetrauch-absaugschlauch-inkl-trichter-selber-bauen/
Build guide published
02/07/2021 at 19:56 • 0 commentsYou can now find the assembly instructions under the following link.
It contains the STL files, the material list, a few assembly suggestions and also a small NodeRed Flow, which should make it easier to control it via the ESPEasy firmware. :)
