Voron 2.4 inspired build using Ender 5 3D Printer frame profiles as a base and some parts laying around :)
Frame VorEnder5.stlStandard Tesselated Geometry - 4.68 MB - 02/14/2023 at 22:15 |
hotend_fan_mount_LED v3.stlStandard Tesselated Geometry - 184.65 kB - 02/12/2023 at 03:08 |
Frame rear left bottom corner v3.stlStandard Tesselated Geometry - 79.18 kB - 01/30/2023 at 05:36 |
led_strip_housing.stlStandard Tesselated Geometry - 69.42 kB - 01/29/2023 at 18:29 |
wiki Fysec Spider V22.urlurl - 153.00 bytes - 01/28/2023 at 19:09 |
VorEnder 5 Buildplate/Heatbed sandwich:
1 Double sided Textured PEI Spring Steel 257x257mm
2 Magnetic rubber plate Energetic 260x260mm
3 Custom made 255x255x6mm glass base
4 260x300mm 468MP Double Sided Adhesive Transfer Tape
5 Creality 235x235x3mm Creality Ender 5 Aluminium Baseplate Heater P=220W 24 VDC
6 Transparent Silicone Rubber Sheet 260x260mm 1mm
Tree z-axis 9mm Linear Rails : MGN9 L=350 KGT Linear Rail with MGN9-H block
Alignment MGN9 Linear Rail with 20x20 Aluminium Extructions V type Profile
Blower Fan: Dual Ball Bearings GDSTIME 5015
Mod Repository: https://github.com/Greg191134/Voron/tree/master/Afterburner%20Optimisation/5015%20fan%20mod
VorEnder 5 3D Printer components list: https://hackaday.io/project/177303/components
STL files: VORON printhead for MicroSwiss hotend https://www.thingiverse.com/thing:4705446
Hotend: Trianglelab Swiss CR10
Creality Ender 5 Electronic controller box with FYSETC Spider V2.2 Motherboard 32Bit RRF Controller Board
Fysetc Spider brackets for Ender5 Controller Box - STL Files to print: https://hackaday.io/project/177303/files
PSU and IEC inlet module AC power socket: https://hackaday.io/project/177303/components
Hey
Could you tell me the difference between front idler 3mm / normal?
Tryed to figure it out by uplaoad date...
Nice project by the way.
What length of belt was used on this project? 4x quantity x length?
Also with the screw amounts and corner brackets, are these for a brand new build even for the frame?
Dan
Terje Io
Hello, I plan to start designing the VORENDER5 PLUS! Do you have assembly plans for the machine?
Thank you for your work ... it's a good job ...
