Frame VorEnder5.stl
Standard Tesselated Geometry -
4.68 MB -
02/14/2023 at 22:15
Download
hotend_fan_mount_LED v3.stl
184.65 kB -
02/12/2023 at 03:08
Download
Frame rear left bottom corner v3.stl
79.18 kB -
01/30/2023 at 05:36
Download
led_strip_housing.stl
69.42 kB -
01/29/2023 at 18:29
Download
wiki Fysec Spider V22.url
url -
153.00 bytes -
01/28/2023 at 19:09
Download
electronic compartner cable drag v6.stl
212.58 kB -
01/28/2023 at 12:09
Download
cable frame anchor.url
url -
137.00 bytes -
01/27/2023 at 14:12
Download
Wago_4x_221-412_mount v3.stl
41.29 kB -
01/27/2023 at 12:48
Download
Vorender 5 Bed v2.dxf
Glass Build Plate 254mmx254mmx6mm Heater 235mm x235mm 220W (Stock Ender 5 Aluminium Heat Bed)
AutoCAD DXF -
81.42 kB -
01/27/2023 at 03:54
Download
Frame rear right bottom corner v11.stl
104.57 kB -
01/23/2023 at 02:42
Download
Z-axis Cable Chains Clip v5.stl
68.64 kB -
01/21/2023 at 21:29
Download
Z_axis_bed_front_bearings_lock_discs v2.gcode
gcode -
1.61 MB -
01/20/2023 at 14:34
Download
z_bed_left v24.stl
197.54 kB -
01/19/2023 at 15:40
Download
z_bed_rear v20.stl
254.57 kB -
01/19/2023 at 15:40
Download
z_bed_right v24.stl
197.54 kB -
01/19/2023 at 15:40
Download
Z_linear_rail_end_stop_front v2.stl
41.98 kB -
01/18/2023 at 00:57
Download
z_carriage_left v14.stl
129.18 kB -
01/17/2023 at 19:38
Download
z_carriage_right v14.stl
129.18 kB -
01/17/2023 at 19:38
Download
Z_carriage_rear v14.stl
230.16 kB -
01/14/2023 at 21:35
Download
Z_linear_rail_end_stop_front v0.stl
2x
113.56 kB -
12/30/2022 at 23:58
Download
Z_linear_rail_end_stop_rear v4.stl
1x
58.68 kB -
12/30/2022 at 23:58
Download
foot spacer 5mm v1.stl
4x
30.45 kB -
12/19/2021 at 14:01
Download
Fysetc Spider V.2.2 mount v15_b.stl
63.75 kB -
12/10/2021 at 11:58
Download
Fysetc Spider V.2.2 mount v14_a.stl
64.05 kB -
12/10/2021 at 11:56
Download
Rubber_Compressor_Foot_Washer_26x5.4x7mm.stl
print 4x
364.46 kB -
11/28/2021 at 16:54
Download
Z_motor_mount_rear_v16.stl
208.19 kB -
11/27/2021 at 18:02
Download
Z_motor_mount_Left_v9.stl
178.50 kB -
11/24/2021 at 12:16
Download
Y_endstop_hall_effect v3.stl
Magnet holder
249.69 kB -
11/21/2021 at 13:06
Download
front_idler_a_bottom-3mm.stl
3mm shorter
137.29 kB -
10/10/2021 at 10:31
Download
front_idler_b_bottom-3mm.stl
3mm shorter
121.81 kB -
10/10/2021 at 10:31
Download
Rubber_Compressor_Foot_Washer_15x5.4x3mm.stl
Print 4x
9.46 kB -
03/31/2021 at 18:42
Download
front_idler_b_top.stl
172.05 kB -
03/11/2021 at 15:24
Download
front_idler_a_top.stl
190.22 kB -
03/11/2021 at 15:24
Download
[a]_ab_drive_upper_washer_v01_x2.stl
86.41 kB -
02/26/2021 at 22:36
Download
[a]_xy_joint_upper_washer_x2.stl
62.78 kB -
02/22/2021 at 04:14
Download
SPACER_PULLEY_5.4X7X0.8.stl
67.27 kB -
02/22/2021 at 04:14
Download
b_drive_frame_upper_v02.stl
749.40 kB -
02/21/2021 at 12:33
Download
a_drive_frame_upper_v02.stl
672.74 kB -
02/21/2021 at 12:33
Download
b_drive_frame_lower_v02.stl
455.26 kB -
02/15/2021 at 10:50
Download
a_drive_frame_lower_v02.stl
380.45 kB -
02/15/2021 at 10:50
Download
