Possible features in the future
- Dimming of the Kingbeam depending on the temperature
- Switch for turning the LED on and off without removing the clipper
- Strong plug-in cable between battery and the LED
- USB charging of the battery
- Bypass of the battery for direct USB Power Supply with a Step Up Converter
- Use the HDD bearings as optic
Open Questions
- How long will the magnets keep enough force for holding the equipment?
- How does the heating of the lamp influence the magnets on the plate?
- Can the optic for the Beamboarder created out of the HDD?
Known Issues
- The Clipper can get damaged after multiple usages.
- The Beam Boarder battery and lamp will fall off by strong impacts and vibrations caused by the street.
- The optic is not finished completely.
