One year ago, I have developped a very fist revision of a custom FOC firmware on the B-G431B-ESC Discovery Kit. The code has been improved and a new firmware revision (V2) will be released soon.
The firmware is tested with a 8108 and a 5008 bruhsless motors. The AS5048A (PWM input) and the AS5600 (I2C) are also tested.
List of improvements :
- 40KHz PWM with CSVPWM
- 40KHz FOC loop
- Current limiter
- 4KHz position and velocity control loop
- Dynamic change of KP and KD when torque enable
- Min/max position limiter
- Maximum velocity limiter
- Thermal protection
- Low voltage protection
A field-weakeming algorithm has been tested, but it will not be in the next release. The ESC is able to spin the motors at their base speed (Kv*Vdc). I think there is no need to spin faster for a hobby robotic application at the moment.
Patrick.
pat92fr
