J031-U5.eqn.txt
STEbus interface.
Analysed but not verified.
plain - 2.14 kB - 11/05/2022 at 01:55
Download
J031-U5.EQN
Disassembled JEDEC file.
eqn - 1.26 kB - 11/05/2022 at 01:55
Download
J031-U7.eqn.txt
Decodes the MPU memory map.
plain - 1.71 kB - 11/05/2022 at 01:55
Download
J031-U7.EQN
eqn - 859.00 bytes - 11/05/2022 at 01:55
Download
J031-U32.eqn.txt
Video timing generator.
plain - 1.51 kB - 11/05/2022 at 01:55
Download
J031-U32.EQN
eqn - 853.00 bytes - 11/05/2022 at 01:55
Download
J031_SGT1V1I2_manual.pdf
SGT1 version 1 issue 2 hardware manual.
Thanks to Steve!
Adobe Portable Document Format - 5.55 MB - 10/23/2022 at 11:24
Preview
W031_SGT1V1I2_manual.pdf
SGT1 version 1 issue 2 software manual.
Thanks to Steve!
Adobe Portable Document Format - 4.85 MB - 10/23/2022 at 11:22
Preview
W031_ver_1_iss_3_.txt
Source code recreated from the partial listing of the firmware in the software manual. It shows the structure of the jump tables and the names of the routines. Full disassembly variable names, generates the original binary.
plain - 101.96 kB - 10/30/2022 at 17:11
Download
W031_ver_1_iss_3_.lst.txt
Latest listing.
plain - 509.06 kB - 10/30/2022 at 17:11
Download
J031-U27-analyser.c
J031-U27 contents as human-readable C array.
Plus a small program to create the timing waveforms.
x-csrc - 2.37 kB - 11/02/2022 at 20:04
Download
J031_SGT1V1I3_hex_bytes.a68.txt
This file produces the firmware hex file from the byte values.
The hex file serves as a reference to check the reverse-engineered source file produces the same hex file.
text/plain - 44.04 kB - 11/06/2021 at 00:09
Download
J031-U27.bin
Binary file for U27, the 32-byte PROM for the state machine.
octet-stream - 32.00 bytes - 10/31/2022 at 01:11
Download
J031-U7.jed
JEDEC file for U7
jed - 2.76 kB - 10/31/2022 at 01:11
Download
J031-U5.jed
JEDEC file for U5
Download
J031-U32.jed
JEDEC file for U32
Download
MC6801-6803 INSTRUCTION SET SUMMARY.pdf
Basically the 6800 with a few extra instructions
Adobe Portable Document Format - 138.11 kB - 02/10/2021 at 00:59
Preview
6803_datasheet.pdf
6803 datasheet
Adobe Portable Document Format - 1.31 MB - 04/10/2023 at 11:34
Preview
Elektor Junior VDU card.zip
Example 6845 board, 2K RAM and monochrome text-only.
The SGT1 had 64K DRAM and colour pixel graphics, more akin to the BBC Micro graphic modes.
Zip Archive - 1.19 MB - 02/10/2021 at 01:55
Download
AN-834.txt
68000 source code for Motorola Application note 834.
Assembles, but not tested.
plain - 12.65 kB - 04/10/2023 at 13:46
Download
