scrumpel8monitor.pdf
Manual of the Scrumpel monitor
Adobe Portable Document Format -
229.04 kB -
10/01/2021 at 18:42
Preview
nforth.hex
This is my own created Forth, Nforth for 6809. It loads at $0100 and runs on that address also. You can load it with the loader of the Scrumpel monitor. I removed a datastack check for speed reasons. This is a version which uses USP in stead of IX and I removed an error in the word dump.
14.55 kB -
04/20/2021 at 07:36
Download
mon6809.asm
On request, the scrumpelmonitor sourcecode. I use ASL as crossassembler.
asm -
17.71 kB -
04/09/2021 at 06:14
Download
othello.hex
A game called othello for the 6809 computer. It resides at $3100 and is loadable with the intelhex loader from the monitor. Its startaddress is $3100
hex -
6.58 kB -
03/31/2021 at 17:05
Download
scrumpel8bv1_1.zip
New gerber files using Scrumpel8bV1.1 schematic.
Zip Archive -
146.52 kB -
02/17/2021 at 08:02
Download
scrumpel8bv1_1.pdf
The corrected schematic diagram of Scrumpel8b with CPU pin 39 connected in the right way.
160.30 kB -
02/17/2021 at 05:06
Preview
scrumpel8b.pdf
Schematic diagram Scrumpel8b
161.19 kB -
02/11/2021 at 06:56
Preview
scrumpel8a.pdf
Schematic diagram Scrumpel8a
157.49 kB -
02/10/2021 at 13:45
Preview
romscrumpel8a.hex
The intel hex file for the 16K rom contains BASIC and the Scrumpelmonitor
hex -
31.86 kB -
02/10/2021 at 13:42
Download
scrumpel8b.zip
Gerberfile for the PCB 68B09ES version
Zip Archive -
141.35 kB -
02/10/2021 at 09:15
Download
scrumpel8a.zip
Gerberfile for the PCB 68B09P version
Zip Archive -
135.93 kB -
02/10/2021 at 09:14
Download
