STM32F407ZGT6 now running on Arduino
09/15/2021 at 04:56 • 0 commentsGot the STM32F407ZGT6 running on Arduino. All I did is select the correct board and pins. See below:
/* * Board: Generic STM32F4 series * Board part number: VCCGND F407ZGT6 Mini * * OLED - STM32F4 connexions * STM OLED 0.66" Sparkfun 64x48 pixels #LCD-13003 * GND 1 GND * 3.3V 2 VDD * PA7 3 D1/MOSI * PA5 4 D0/SCK * -- 5 D2 * PB0 6 D/C * PB1 7 nRESET * PA4 8 nCS */ ////////////////////////// // MicroOLED Definition // ////////////////////////// #define PIN_RESET PB1 #define PIN_DC PB0 #define PIN_CS PA4 #define DC_JUMPER 0 // Set to either 0 (default) or 1 based on jumper, matching the value of the DC Jumper // Also connect pin PA5 to SCK and pin PA7 to MOSIThe rest of the code is the same as the Micro OLED example.
Jacques Pelletier
