Received the v2.0 version of the backplane. The backplane is now 4-layer, with ground and power planes as layer 2 and 3. I forgot to remove the ground-fill on the bottom layer, let's see how that works out.
Also published the project files on GitHub and write down the memory map (as it is right now) in the project details.
Xander Maas
