CircuitPython code is below.
First CircuitPython version: https://github.com/hwiguna/PicoMandelbrot
Latest MicroPython version: https://github.com/hwiguna/HariFun_202_MandelbrotPico
Every platform needs a Mandelbrot
I added another button to toggle between hires and lores.
I also converted the code to MicroPython. I think it's faster, but I never did a speed comparison.
Code is on GitHub:
Added three potentiomenters and three pushbuttons to navigate the Mandelbrot.
MAX_ITER = 80
def mandelbrot(c):
z,n = 0,0
while abs(z) <= 2 and n < MAX_ITER:
z = z*z + c
n += 1
return n
# Mandelbrot adapted for Pi Pico by Hari Wiguna from:
# https://www.codingame.com/playgrounds/2358/how-to-plot-the-mandelbrot-set/mandelbrot-set
def main():
import board # Pi Pico Board GPIO pins
import displayio # Python's multi layer graphics
import adafruit_displayio_ssd1306 # OLED Driver
import busio # Provides I2C support
import time
from adafruit_display_shapes.line import Line
import math
from hari.mandelbrot import mandelbrot, MAX_ITER
WIDTH, HEIGHT = 128, 64 #32 # Change to 64 if needed
displayio.release_displays() # Just to be safe
def SetupDisplay():
# So we can communicate with our OLED via I2C
i2c = busio.I2C(scl=board.GP3, sda=board.GP2)
#while not i2c.try_lock():
# pass
#print("i2c address is = ",i2c.scan())
# How displayio talks to physical screen
display_bus = displayio.I2CDisplay(i2c, device_address=60) # was 0x3A, reset=oled_reset)
# display represents the physical screen
display = adafruit_displayio_ssd1306.SSD1306(display_bus, width=WIDTH, height=HEIGHT, auto_refresh=False)
# Group is a list of TileGrids that display would render on physical screen
group = displayio.Group(max_size=1)
display.show(group)
return (display, group)
def SetupTileGrid():
#-- Create a bitmap --
bitmap = displayio.Bitmap(WIDTH, HEIGHT, 2)
#-- Create Palette --
palette = displayio.Palette(2)
palette[0] = 0
palette[1] = 0xFFFFFF
#-- Create TileGrid --
tileGrid = displayio.TileGrid(bitmap, pixel_shader=palette)
return bitmap, tileGrid
#=== MAIN ===
(mDisplay, mGroup) = SetupDisplay()
(mBitmap, mTileGrid) = SetupTileGrid()
mGroup.append(mTileGrid) #add the TileGrid to the group
RE_START = -1.5 #-2
RE_END = -1 #1
IM_START = -.25 #-1
IM_END = .25 #1
xOffset = -0.8
RE_START = -2 + xOffset
RE_END = 2 + xOffset
IM_START = -1
IM_END = 1
MAX_ITER = 80
for x in range(0, WIDTH):
xx = RE_START + (x / WIDTH) * (RE_END - RE_START)
for y in range(0, HEIGHT):
yy = IM_START + (y / HEIGHT) * (IM_END - IM_START)
c = complex(xx, yy) # Convert pixel coordinate to complex number
m = mandelbrot(c) # Compute the number of iterations
color = 1 - int(m/MAX_ITER)
if color>0: mBitmap[x,y] = 1 # Plot the point
if x % 4 == 0: mDisplay.refresh()
mDisplay.refresh()
while True:
pass
I agree -- every platform needs a Brot. Nice job here.
I stumbled across a Mandelbrot generator made completely with logic gates. It was done entirely within a logic simulator, but it should be possible to build a hardware version from discrete 74xx series chips. I'd dearly love to do that.
Watch for this week's Link's article for more info.
OMG! That's impossible!? I suppose, it's "just" a specialized version of discrete logic computers. Looking forward to the article.
