1Case Modifications
The case needs minor modifications to be able to connect the solar panel with wires.
Note: When viewing the LCD the wires should be exit the case on the left side. The BLE antenna is on the right and i expierenced a worse RSSI while the first attempt to exit the wires on the right side.
2Soldering
Just solder GND and Voltage wires a shown. Dont forget to place in a diode, this is necessary that the solar panel does not discharge the Supercap overnight.
3Supercapacitor
Remove the "-" pin from the supercapacitor. And carefully bend the "+" pin down. The capacitor fits into the slot of the CR2032.
4Fit the capacitor in the case
