Hackaday.io Hackaday.io
Sign up Log in
waterproof voice recorder for the shower
those waterproof pads of paper are cool and all, but not when you're the one paying the water bill. this will be faster.
kristina-panoskristina panos
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
7 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
1.2k
7
6
5
Team (1)
  • kristina-panoskristina panos
Join this project's team
  • a thread on the topic
  • OKW enclosures
hardware
ongoing project
This project was created on 02/28/2021 and last updated 5 年前.
Description
This will be a waterproof voice recorder. How hard could it be? I don't know, it'll use an SD card or something and have playback. So after the shower, I take it up to my office and transcribe my shower thoughts.
Components
  • 1 × VS1053 Codec + MicroSD Breakout - MP3/WAV/MIDI/OGG Play + Record - v4 https://www.adafruit.com/product/1381
  • 1 × OKW Enclosures slim-case https://www.okwenclosures.com/en/Plastic-enclosures/Slim-Case.htm
Project Logs
Collapse
  • gathering supplies
    kristina panos • 03/25/2021 at 15:14 • 0 comments
    My enclosure arrived and is definitely big enough for the application. I also bought a MP3/MIDI/WAV/OGG play + record module with an SD card slot from adafruit. Hopefully the only other thing I need is a microphone, an SD card, and a speaker or an audio jack so I can play the files back without removing the SD card. Oh wait, the module comes with an audio jack.
  • a possible enclosure is on the way
    kristina panos • 03/05/2021 at 16:01 • 0 comments
    My buddy at OKW Enclosures is sending me a waterproof version of their newest product, the slim case. https://www.okwenclosures.com/en/Plastic-enclosures/Slim-Case.htm
  • here's a more expensive thing I could hack
    kristina panos • 03/01/2021 at 20:05 • 0 comments
    https://www.amazon.com/WinBridge-Amplifier-Microphone-Loudspeaker-Waterproof/dp/B07BDJ4TRQ/
    Bonus: I get to pretend I'm the Sham-wow guy in the shim-sham-shower.
  • here's a thing I could hack
    kristina panos • 02/28/2021 at 23:14 • 0 comments
    This thing is waterproof and has a microphone for all those calls you take in the shower. Maybe I could hack it into a recorder.
    https://www.amazon.com/SB510-Resistant-Bluetooth-Handsfree-Speakerphone/dp/B00IN2S072/
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
kristina panos wrote 03/03/2021 at 14:28 • point
@Simon Merrett Hmm, yes, I suppose the piezo would have to be rather close. Whatever I end up with, it doesn't have to sound great, just good enough to transcribe. Maybe I could strap the whole apparatus over my mouth and around my head, or make a face mask from a shower cap and only cover my mouth.
Simon Merrett wrote 03/03/2021 at 16:38 • point
:-) Is a waterproof solution the only option? If you have a rigid shower screen, maybe you could clamp a mic against the outside of that and use it as a pickup? Or would a phone on a shelf somewhere else in the bathroom be sensitive enough? Totally understand if this is an excuse to rabbit hole with some hacking though!
kristina panos wrote 03/03/2021 at 17:02 • point
It's mostly about hacking something together! But I should use a phone or something in the meantime. Maybe I'll try using my little digital voice recorder.
Simon Merrett wrote 03/03/2021 at 17:16 • point
@kristina panos I keep thinking of the Teensy audio library and shield, although the website says it still can't currently continuously record to SD https://www.pjrc.com/teensy/td_libs_AudioRoadmap.html. Not sure how big a SPI flash chip you would need for what you are planning to record, in lieu of an SD card.
Simon Merrett wrote 03/01/2021 at 09:40 • point
Shame you can't keep all your notes to a total of ten seconds, otherwise this is right up your street https://www.dfrobot.com/product-1507.html
kristina panos wrote 03/01/2021 at 20:07 • point
That is cool. I once waterproofed a piezo in Plasti-Dip. I wonder if it would pick up my voice well enough in competition with the shower.
Simon Merrett wrote 03/02/2021 at 08:19 • point
Maybe you need to wear a throat mic :-)
AMB23 (RTL8722DM MINI) contains an onboard SD card module that eases the file reading/writing to the micro SD card.
Project Owner Contributor
AMB23 Fatfs SDIO - File system in SD card
splendidemendaxSplendide_Mendax
A card reader that uses black and white squares to identify a card.
Barcode Binary Card Reader
pete-prodoehlPete Prodoehl
Turn off your credit card and experience true freedom.
Credit card blocker
merwane-hamadiMerwane Hamadi
UD is open standard that uses SD Card form factor but is not bound to SD card specification.
UD Universal Digital Card
antti-lukatsAntti Lukats
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "waterproof voice recorder for the shower", please tell us the reason.
Send message
Remove Member
