1Watch the HackadayU Classes
Amazing Class 10/10
AVR: Architecture, Assembly & Reverse Engineering
- I realized that this course was way above my level, way too late in the game.
- Had invested in this and wanted to see this through.
- So just push through! You can do it!
2Code the program in C
Make sure it works.
3Try to reverse engineer the code (cheat) by looking at the assembly code generated
Wokwi is the best Arduino simulator on the planet!
Proteus is crap.
4Weep as it gives you random LEDs lighting up
6 hours of frustration down the drain :(
5Start from scratch and test your code after writing each function
Prepare to press a lot of Ctrl+F's in AVR Instruction Set Manual.
Also, Wokwi's Web Debugger is your best friend. Check the registers and program counter if something doesn't work.
6Pat yourself and do a victory dance
YOU DID IT!
Paulson K Antony
