Hackaday.io Hackaday.io
Sign up Log in
TLBS Curtains
Using threadless ball screws to open and close curtains, the elegant way.
es-pronkE/S Pronk
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
Public Chat
384
1
5
8
Team (1)
  • es-pronkE/S Pronk
Join this project's team
shelved project
MISC
Curtains ball screw 3D Print
This project was created on 03/03/2021 and last updated 5 years ago.
Description
I like automatic curtains, but it don't like the belt systems that usually drive it. I also want to open or close my curtains manually from time to time, without destroying the whole machine.
So I thought I'd make threadless ball screws and do some math to calculate the angles of the bearings such that each ball screw moves at R*s*(n mod 1) where R is a rotation of the rod / shaft / tube, s is a scaling factor and n is 1 to N (number of ball screws) or -1 to -N. This way the screws spread out evenly when the rod is rotated and it even works both ways at the same time!
Details
Log In/Sign up to comment
Sign up with Github
OR
Muphins wrote 01/26/2022 at 08:47 • point
That is Awesome !
I can't wait to see the details on the design !
I had a Dremel which died in 2017 lying around. At the time, I didn't find the root of the problem. Now I did and it works like a charm !
Project Owner Contributor
Dead Dremel 3000 repair (open stator winding)
ilyas-sioudaIlyas Siouda
I'm trying to write a theory of everything using nothing: Cavitative String Theory
Zero
undeadchicken1981undeadchicken1981
Hard to be a maker or a small company without so much time and knowledge for calculations. Why not using copo.app ?
Copo : Makers' online calculator
guillaumesguillaumes
my first attempt at a cosplay costume
Guardians of the Galaxy Starlord Costume
john-griffithsJohn Griffiths
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "TLBS Curtains", please tell us the reason.
Send message
Remove Member
