NextionDisplayTopESP32-1.1.stl
Standard Tesselated Geometry -
55.36 kB -
04/09/2021 at 11:18
Download
ESP32 NextionDisplayCaseBack.stl
Back cover for nextion control box print 25% Fill
36.70 kB -
04/05/2021 at 11:16
Download
ESP32 Display Hinged Plate.stl
Small hinge part for display Tilt print 100% fill
17.86 kB -
04/05/2021 at 11:16
Download
ESP32 Display plate Hing.stl
Display Tilt plate for new Remote display print 25% fill
8.68 kB -
04/05/2021 at 11:16
Download
10-CtrlBox.stl
Housing for Main board print 25% Fill
158.82 kB -
04/05/2021 at 11:12
Download
06-CtrlCover.stl
Cover for Control Housing print 100% fill
1.45 kB -
04/05/2021 at 11:12
Download
01-EncoderCover-Large.stl
Fits on back of Encoder housing Print 25% fill
56.82 kB -
03/05/2021 at 15:48
Download
02-EncoderHousing-Large.stl
Holds encoder and fits on back of Nema 17 Print 25% fill
49.50 kB -
03/05/2021 at 15:48
Download
03-CenterDivide-ctrlEnd.stl
Divides the space between the motor housing and the control box Print 25% fill
26.25 kB -
03/05/2021 at 15:48
Download
04-CenterDivide-batEnd.stl
Divides the space between the two battery bays Print 25% fill
8.29 kB -
03/05/2021 at 15:48
Download
05-BatCover.stl
Slide in cover for top of battery end Print 100% fill
1.84 kB -
03/05/2021 at 15:48
Download
07-BatTab.stl
Print 100% fill 8No. Required 4 per battery bay
1.45 kB -
03/05/2021 at 15:48
Download
08-BeltEndCover10mm.stl
Small cover to hold the belt end Print 100% fill 3No. required
3.99 kB -
03/05/2021 at 15:48
Download
09-BeltEndKeeper.stl
33.68 kB -
03/05/2021 at 15:48
Download
11-MotBox.stl
Housing for the Nema17 Print 25% fill
122.05 kB -
03/05/2021 at 15:48
Download
14-CtrlBoxCover.stl
Print 100% fill
27.82 kB -
03/05/2021 at 15:48
Download
15-FootBatLeftB.stl
Print 25% fill 3 shells
26.64 kB -
03/05/2021 at 15:48
Download
16-FootBatRightB.stl
26.64 kB -
03/05/2021 at 15:48
Download
17-FootCtrlLeft.stl
26.55 kB -
03/05/2021 at 15:48
Download
18-FootCtrlRight.stl
26.64 kB -
03/05/2021 at 15:48
Download
19-SledCoverBottomV1.1.stl
Print 40% fill 3 shells
120.20 kB -
03/05/2021 at 15:48
Download
19-SledCoverTop.stl
137.48 kB -
03/05/2021 at 15:48
Download
20-BatBoxLeft.stl
75.38 kB -
03/05/2021 at 15:48
Download
21-BatBoxRight.stl
57.41 kB -
03/05/2021 at 15:48
Download
22-RailConectorBatEnd.stl
Print 100% fill
38.17 kB -
03/05/2021 at 15:48
Download
23-RailConectorCrtlEnd.stl
Print 100% fill
34.07 kB -
03/05/2021 at 15:48
Download
24-break-body.stl
Print 100% fill
7.41 kB -
03/05/2021 at 15:48
Download
25-BreakSwitch.stl
Print 100% fill
20.59 kB -
03/05/2021 at 15:48
Download
