Recently I bought a 250F and a 750F 3.8V Lithium Ion Capacitor from Aliexpress, it is manufactured by Cda. Are they good?
![]() 250F 3.8V | ![]() 750F 3.8 |
I compared it to other LICs from well know brands like Vinatech and Eaton. I compared datasheets, measured capacitance and measured leakage. To measure the capacitance I used my own electronic load set at a constant current of 500mA and and measured the time it takes to drop from 3.8V to 2.5V. Capacitance is calculated Q(F)= )=t(s)*0.5A / (3.8-2.5)
To measure the leakage I charged them up and every day I measured the voltage decay with a bench multimeter and calculated leakage current using following formula leakagecurrent(A)=capacity(Farad)*(yesterdaysvoltage[V]-todaysvoltage[V])/t[s]
Vinatech VEL13353R8257G ![]() | Cda LIC1620Q3R8257 ![]() | Eaton HS1625-3R8227 ![]() | Cda LIC1840Q3R8757![]() | |
specified capacitance (F) | 250 | 250 | 220 | 750 |
dimensions (diameter x length mm) | 12.5x35 | 16x20 | 16x25 | 18x40 |
operating temperature (Celsius) | -25 +70 | -40 +85 | -15 +70 | -40 +85 |
life cycles | 20k (10%) | 30k (30%) | 500k (30%) | 30k (30%) |
Current continous A | 0.75 | 0.75 | 1.1 | 3 |
Current peak A 1s | 5 | 10 | 15.3 | 30 |
ESR AC 1kHz mOhm | 50 | 50 | 100 | 25 |
specified leakage current 72h/uA | 10 | 5 | 12 | 23 |
price at qty1000 | $1.90 at Vinatech | $1.90 at a Aliexpress seller | $8.60 at mouser | not requested |
measured capacitance CC 0.5A | 301F (+20%) | 220F (-14%) | 228F (+3%) | 761F (+1%) |
measured leakage 72h/uA | 3 | 1 | 2 | 4 |
The CDA 250F LIC has 14% lower than specified capacitance, not perfect but not bad either. The leakage of all LICs after 72hrs is very low, less than 5uA, so it becomes insignificant for most energy harvesting application.
Conclusion: the 250F and 750F 3.8V LICs from Cda are not bad at all. The specs are good, the measured capacitance is not bad and leakage is good. For the Cda 250F the price is $1.90 in qty1000 same as the Vinatech 250F.
Thank you for this. I just got a CDA LIC1840Q3R8757 - not sure how to charge it for use. How did you approach it?
Set your bench power supply to 3.8V and limit the current to 0.75A, then connect to the LIC
thanks very much; and for how long - or how do you know to stop?
Charging a 750F capacitor at 750mA from 2.5V to 3.8V takes 750F*(3.8V-2.5V)/0.75A= 1300s=22 minutes. Either you wait 22 minutes of check the current on the bench power supply, if it is 0.0A charging is completed.
Perfect, thanks for your help Jasper!
