Taking it apart (mostly)
03/13/2021 at 23:44 • 0 commentsI took off the outer plastic casing and most of the extrusion assembly. I also removed the print bed and the Z axis, along with the filament tubes. I unplugged and took out the motherboard at the end.
Next up, attaching a laser. This will probably be a while as I have some other important projects to work on first...
A-A-W
