Hackaday.io Hackaday.io
Sign up Log in
Simple brushless ESC tester
Simple solution to test brushless ESC's.
loudLouD
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.8k views
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
1.8k
0
7
7
Team (1)
  • loudLouD
Join this project's team
  • ESC Phase Tester
completed project
hardware
esc brushless BLDC Motor test
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 03/15/2021 and last updated 5 years ago.
Description
I needed a simple solution to test brushless ESC's for repairs. So I made one.
I found a video of someone using 3 lightbulbs to test a brushless ESC. I made this with 3 led strips instead of lightbulbs and the result was the same.
From there on I got help from a friend and he pointed out that with these 3 led strips I could only see either the high or low phase of the esc under test.
I added 3 more led strips in reverse and created the first version of my simple esc tester.
Ofcourse this was nice, but it had wires everywhere and was not really portable. My friend and I created a schematic and PCB in Kicad. I ordered the PCB at OSHPark.com and there we go, a simple esc tester.
Check the github link for more information.
See the photo's and videos on instagram for how it works.
Want one for yourself? You can order 3 boards for only €2.20 at OSHPark.com
https://oshpark.com/shared_projects/xSDHzsAY
You will need:
6x LED 1210 footprint
3x Resistor 1206
Project Logs
Collapse
  • soldering the final version
    LouD • 03/15/2021 at 12:09 • 0 comments
    https://www.instagram.com/p/CMCeTE0nUJp/?igshid=1htaidmnh95xb
  • end result in action
    LouD • 03/15/2021 at 12:08 • 0 comments
    https://www.instagram.com/p/CMCfAJSHQdu/?igshid=1nevolnncvokv
  • version 2 in action
    https://www.instagram.com/p/CLb5iyfnDAm/?igshid=1ovw37yq003xy
  • end result
    LouD • 03/15/2021 at 11:54 • 0 comments
    final version
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
just only 46 Self flashing leds
Project Owner Contributor
Chaos LED flashing heart
bobriciusbobricius
The classic Geneva Wheel mechanism, but sillier
PCB Geneva Wheel
sam-ettingerSam Ettinger
using a sphere form factor for LED display
globe RGB
mylesMyles
diy 3 coordinate touch probe for CNC machine.
3D Touch Probe
jimmykJimmyK
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Simple brushless ESC tester", please tell us the reason.
Send message
Remove Member
