Based on my experience with the DJI RoboMaster S1's battery, I had assumed the FPV drone also communicated with the battery over I2C. I was wrong about this. The data transfer looks like CAN bus.
My logic analyzer doesn't read CAN packets so I'll need to figure out a way of reading this data. I thought I'd share this information in case any of you are interested.
Edit (April 1, 2021): Thanks to Andrew Young who informed me my logic analyzer was capable of decoding CAN. This is the exported text of the CAN data:
Time [s],Packet,Type,Identifier,Control,Data,CRC,ACK 2.111320843750000,0,DATA,0x554,0xE,0xEF 0xEE 0x93 0xE9 0x7B 0xAE 0x8D 0xBF,, 2.114893812500000,1,DATA,0x138,0xF,,, 2.126467750000000,2,DATA,0x153EFBE9,0xE,0x67 0xFE 0xD6 0x15 0xE9,, 2.310771906250000,3,DATA,0x554,0xE,0xEF 0xEE 0x93 0xE9 0x7B 0xAE 0x8D 0xBF,, 2.314893750000000,4,DATA,0x138,0xF,,, 2.515036843750000,5,DATA,0x138,0xF,,,
Hi, did you tried to made decoy communication to enable the use of any battery?
Thanks for the detailed posts!
Great job! You did it over pins on battery connector or pcb testpoints? Can't seem to find pinout of this drone/battery yet
The Saleae Logic software should be capable of decoding CAN - I have the same version and CAN is available as an analyser in the list.
https://support.saleae.com/protocol-analyzers/supported-protocols
WOW! I can't believe I never noticed those other protocol options. I always just used asynchronous serial, I2C or SPI.
I added the decoded data to the log.
Thank you for letting me know about the other protocols.
