Rebuilding a laptop case in Lego and Lego compatible parts
Can apply the similar method with Acer swift 3 Linux model to run it with automate system?
Is this passible to adjust these cases on Dell Laptop? I want to it on my laptop to make the case screen cool.
Is there anything that can't be built with LEGO? I like the organic shape and color palette you ended up with on this one!
Thank you :) Will try to make it more firm. As well as I plan to rebuild the base of the case when it will crumble.
devans013
STEAL-THIS-HARDWARE
B2
sphereinabox
Yes, delete it Cancel
You are about to report the project "Lego laptop case", please tell us the reason.
