Computer case "everyone" can make
A simple case that can be customized to fit your need. A case that nearly everyone can build.
b2B2
I'm in the making of a open base computer case that will be easy to build at home whit parts that can be ordered online or bought at a local hardware shop. Some parts will be needed to ether have a laser cuter, 3D printer or be handy whit the jigsaw.
  • 8 × Corners Plastic corners that fits your profiles
  • 5 × 335mm 10mm rod
  • 8 × 300mm 20X20mm alu profiles
  • 1 × lot of P clips
  • 4 × 150mm Switches and Relays / Electromechanical Relays
View all 6 components
Mike Maluk wrote 03/23/2016 at 05:15 • point
This still going on? Super neat idea!
Ashish wrote 07/11/2015 at 07:51 • point
Finally someone is bored and wants gets out of usual rut!
Jasmine Brackett wrote 05/20/2014 at 18:25 • point
Would love to see more info about this.
