I have printed some test pieces, I identified weaknesses in the frame and made another version with ribs and a thicker top section (left one) where the screws will be installed to fix it to the wall. It has improved however there is still a bit of weakness so ill have to improve it further. Also had an issue with the stepper mounting screw holes being too thin and snapped off when I tried to remove the support material.
