I have just got my POE board and will be doing some tests later on. This is the LILYGO ESP32 POE. The image on the listing was the WROVER module but I received the WROOM module but that's okay since this is the module I intend to use on my custom PCB. This is my first board so I also bought the programming board along with it since the programming header on the board does not use standard 2.54mm header pin spacing.
I want to get some kind of program working first so I can see if the motor will be able to roll the blinds up.
