1Step 1
For every other hole on the pegboard, use a drill bit to slightly widen the hole. Do this until you have 529 widened holes.
2Step 2
Snugly fit each LED inside every hole.
3Step 3
In order to deliver enough power to every LED strip, you have to connect every 3 or 4 strips together using wires and solder.
4Step 4
Use an Xacto knife to cut a plus shape into each ball. Do NOT burn holes into the Ping Pong balls as it releases toxic fumes.
5Step 5
Hotglue every Ping Pong ball on top of each LED
6Step 6
Connect the power supply, the WEMOS D1 Mini, and Nintendo Nunchuk.
AdroitConfusion
