1Assemble the hardware
- Attach the Raspberry Pi camera to the CSI slot (nearest the USB ports)
- Attach the screen (make sure any additional power cables for the screen are also plugged in)
- Plug in the Raspberry Pi
2Download our software
The quick-start section on our GitHub always has the most recent installation steps. Currently, you can install PosturePerfection by doing the following:
- Open a terminal on the Raspberry Pi
- Download the installation script using:
wget https://raw.githubusercontent.com/ESE-Peasy/PosturePerfection/main/PosturePerfection_install.sh
- Run the installation script with:
sh PosturePerfection_install.sh
3Run PosturePerfection
On your terminal type the following to start PosturePerfection:
./PosturePerfection
