I built an amplifier for my new speakers, designed as a dual-mono system with two completely independent amplifiers. Each amplifier has its own power supply and DC speaker protection on a 4-layer PCB. The output power is 50W at 8 ohms, with a balanced supply voltage of +/- 35V, and each amplifier has a dedicated winding on the power transformer. I also built a simple stereo loudness control on a separate PCB.
Details
You can find original schematics here and here (only in Slovak and Czech language). I'm not the author of these circuit, i just made some modifications.
I 3D printed a simple front and rear panel, top cover and potentiometer knob. Unfortunately, panels are a bit warped but it doesn't look so bad. Heatsinks are mounted on wood board.
