2-ch. regulated variable power supply 0...30V/2x3A
The power supply has preregulator with output filter folowed by regulator. Each channel can works in CV or CC mode.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A single board (100x160mm) two-channel regulated variable power supply. Both channels are independend with separated power input and voltage / current adjust. The power supply has two stages: preregulator with output filter folowed by regulator. Each channel can works in CV or CC mode and has overcurrent protection. Output range is 0. - 32V / max. 3A. on each channel.
