Finally I managed to find time to configure the Motorola monitor Assist09 to the MicroKit09. It is a very small monitor that uses an ACIA (6850) and optionally a PTM (6840) to work.
Short introduction into Assist09.
All commands and hex values should be uppercase. Commands and arguments
are separated by one or more spaces.
A complete description and assembly listing of Assist09 is in the
Motorola MC6809-MC6809E 8-Bit Microprocessor Programming Manual, Appendix B
Command Name Description Command Entry
Breakpoint Set,clear,display, or delete breakpoints B
Call Call program as subroutine C
Display Display memory block in hex and ASCII D
Encode Return indexed postbyte value E
Go Start or resume program execution G
Load Load memory from tape L
Memory Examine or alter memory M
Memory change or examine last referenced /
Memory change or examine hex/
Null Set new character and new line padding N
Offset Compute branch offsets O
Punch Punch memory on tape P
Registers Display or alter registers R
Stlevel Alter stack trace level value S
Trace Trace number of instructions T
Trace one instruction -
Verify Verify tape to memory load V
Window Set a window value W
The monitor code range is F800-FFFF, RAM is expected at 1800, ACIA at A400 and the PTM at A800.
fjkraan
