Here an image of the MicroKit09 with the ACIA/PTM extension for usage with the Assist09 monitor.
The I/O board and the MC6821 is not used in this setup.
Just tried to set a breakpoint to test the PTM, and it worked!
>D 1000
>D 1000
0 1 2 3 4 5 6 7 8 9 A B C D E F
1000 12 12 12 12 12 BE 10 67 A9 FF FF EF 00 DA 10 24 .......g.......$
>B 1002
1002
>G 1000
PC-1002 A-00 B-00 X-20FE Y-F002 U-18C2 S-1851 CC-D4 DP-00
The Assist09 monitor is described in the Motorola MC6809-MC6809E 8-Bit Microprocessor Programming Manual (M6809PM/AD, 1981), Appendix B.
fjkraan
