Assist09 for the MicroKit09 (with ACIA/PTM extension)
A project log for microKit09 MK2
Recreation of a 1983 MC6809 single board computer
fjkraanfjkraan 08/01/2025 at 09:500 Comments
Finally I managed to find time to configure the Motorola monitor Assist09 to the MicroKit09. It is a very small monitor that uses an ACIA (6850) and optionally a PTM (6840) to work.
Short introduction into Assist09.
All commands and hex values should be uppercase. Commands and arguments
are separated by one or more spaces.
A complete description and assembly listing of Assist09 is in the
Motorola MC6809-MC6809E 8-Bit Microprocessor Programming Manual, Appendix B
Command Name  Description                              Command Entry
Breakpoint    Set,clear,display, or delete breakpoints B
Call          Call program as subroutine               C
Display       Display memory block in hex and ASCII    D
Encode        Return indexed postbyte value            E
Go            Start or resume program execution        G
Load          Load memory from tape                    L
Memory        Examine or alter memory                  M
              Memory change or examine last referenced /
              Memory change or examine                 hex/
Null          Set new character and new line padding   N
Offset        Compute branch offsets                   O
Punch         Punch memory on tape                     P
Registers     Display or alter registers               R
Stlevel       Alter stack trace level value            S
Trace         Trace number of instructions             T
              Trace one instruction                    -
Verify        Verify tape to memory load               V
Window        Set a window value                       W
Screendump of a Assist09 session
The monitor code range is F800-FFFF, RAM is expected at 1800, ACIA at A400 and the PTM at A800.
