Wk5 Kangaroo2_Pillow.ghgh - 23.08 kB - 06/01/2021 at 21:18 |
Wk5 Anemone Loop.ghgh - 22.80 kB - 06/01/2021 at 21:18 |
Wk5 Kangaroo2_VoronoiBubble.ghgh - 14.65 kB - 06/01/2021 at 21:18 |
Wk5 Kangaroo2_MultiVault.ghgh - 24.30 kB - 06/01/2021 at 21:18 |
Wk4 Fields Advanced.ghHeavy filegh - 34.46 kB - 05/25/2021 at 21:33 |
Wk4 Vectors.ghgh - 22.52 kB - 05/25/2021 at 21:33 |
Wk4 VectorTree.ghL-System using Orient Directiongh - 20.53 kB - 05/25/2021 at 21:33 |
Wk4 Fields Basic.ghgh - 21.51 kB - 05/25/2021 at 21:33 |
Wk4 BasicAttractor.ghgh - 18.10 kB - 05/25/2021 at 21:33 |
Wk3 ImageSampler.ghSuccess Kid - Circles using Brightness on Image as radii. More complicated version https://discourse.mcneel.com/t/laser-cut-portrait/89579/23gh - 3.57 MB - 05/19/2021 at 15:22 |
Wk3_CellandMorph with Randomness.ghPoints are moved in a random angle and random distance. Max distance controls the max deviation of the points.gh - 68.83 kB - 05/19/2021 at 12:53 |
Wk3 ProjectEgg.ghMy attempt to recreate the project https://projectegg.org/gh - 284.29 kB - 05/19/2021 at 12:52 |
Wk3 O-14.ghBuilding O-14 by RUR Reiser Umemoto. It doesn't have a gradient in window opening size but this file uses one. http://www.reiser-umemoto.com/o-14.htmlgh - 24.78 kB - 05/19/2021 at 12:52 |
Wk3 Manipulating The Grid_Class File.ghWhat we did in classgh - 29.44 kB - 05/19/2021 at 12:52 |
Wk2 Flowers.ghThree flowers. The first is the one we covered in class.gh - 53.99 kB - 05/15/2021 at 13:14 |
Wk2 Galaxia_BurningMan.ghMy quick attempt to recreate the geometry that was used at Burning Mangh - 43.90 kB - 05/15/2021 at 13:14 |
Wk2 Weaving.ghVarious weaving patterns - Basic, Twill, Satin.gh - 102.58 kB - 05/15/2021 at 13:14 |
WK1_2_ComplexBridge - See Comments.ghThis grasshopper files uses hidden wires to tidy up the file. They will be explained in week 2. If you are unsure of any component, click cntl + alt and the component and it will reveal where in the menus the component can be found.gh - 36.18 kB - 05/05/2021 at 17:47 |
WK1_2_BasicBridge.ghTidied file up for clarity.gh - 25.02 kB - 05/05/2021 at 17:47 |
WK1_1_First Worksheet.ghgh - 35.12 kB - 05/04/2021 at 21:38 |
