Discoloration
A project log for CIJ Printer
An Open Source Continuous Inkjet Printer
dominik-meffertDominik Meffert 08/13/2025 at 06:070 Comments
When mixed with pure ethanol, the sandarac ink has a slightly yellow color depending on the mix ratio, but over the last few months, the ink inside the printer turned green, which shouldn't be happening.
Transparent Ethanol on top of green Sandarac Ethanol Ink
Since yellow mixed with blue gives us a green color, I suspect that the blue color from the housing of the ink tank got dissolved by the ethanol and mixed with the ink. This already happened before when I used blue colored PU tubes for testing out the falling ball viscosimeter. After a while the transparent ink turned blue from the color of the tubes.
Blue Tank Housing
Since the green color is an unwanted ink contamination, I started cleaning the system by flushing out the green ink.
Flushed out Green Ink
Here you can see the green ink compared to highly concentrated sandarac ink.
Sandarac Ink and Green Ink
To prevent discoloration in the future, I got a new tank made out of white Polypropylene.
Unfortunately, the new one is no longer transparent. To still see the fluid level of the tank, I added a fluid level indicator to the side of it (just a 4mm PE tube).
When I disassembled the old tank, I found fittings with a suspicious blue color on top of the PTFE tape close to the tank.
Blue Color on top of the PTFE Tape
After I connected the new tank I flushed the system with pure ethanol and loaded it with fresh ink.
New White Tank
After loading the new ink I let it sit inside the machine for a week of vacation.
When I came back, I saw that a certain part of the tubes had turned green again.
A new green Color appeared
The chances that the blue color from the anodized aluminum had also turned the ink green were lower than that of the tank housing, but to eliminate all risk, I ordered new fittings to replace the blue anodized parts.
When I disassembled the fittings, I saw that there was also a lot of blue residue inside them. Since the ink is not corrosive I could rule out that it was a sign of brass corrosion. Instead, I think it could either be color from the anodized fittings or just a buildup of the blue pigments from the tank housing that got stuck on the fitting walls.
Blue Residue on the Fitting Walls
When the new fittings arrived I once again cleaned the printer and loaded new ink into it.
New Stainless Steel Fittings
I mixed 500ml of new sandarac ink and loaded half of it into the printer.
Ink Tank and new Sandarac Ink
But when I came back to the machine a day later, the same tube turned green once again.
The green color appeared again
I'm currently suspecting that there is still some residue on the walls of some fittings, which turns the ink green, and that after more flushing, it will disappear at some point, since there are no more colored parts in the system.
