8 Digital Outputs can be used as active/passive output, connect a relay or PWM on every channel;
8 Digital Inputs can be used as dry contact with input voltage up to 30V, with frequency measurement and pulse calculation features;
7 Analog Inputs -10..10V with overvoltage protection. Up to 1M Sample rate;
1 Analog Diff Input -1.5..1.5V with overvoltage protection. Up to 1M Sample rate;
2 Analog Outputs 0..10V output with short circuit protection. Sin/triangle/saw/random wave generator features;
4 UARTs or SPI or I2C for connection with external devices like ADC, DAC, external memory, sensors etc.;
Ethernet, Wi-Fi to connect with computer, RPi or Smartphone for total galvanic isolation;
USB for simple connection with computer, RPi or Smartphone;
Supply voltage 5V.
JPEG Image - 1.30 MB - 04/05/2021 at 07:52
Preview
2 Digital Outputs
2 Digital Inputs
Supply voltage 5V
Fixed power supplies 3.3В, 500мА, 5В, 300мА
Managed power supplies 1.25..32V 5W
4 managed USB hub ports
USB and UART management from Fork/PC
Spi for connecting the LCD screen
JPEG Image - 1016.76 kB - 04/05/2021 at 07:52
Preview
Device under testing. NOTA mole tracker
JPEG Image - 136.22 kB - 04/05/2021 at 07:54
Preview
Compatibility board
JPEG Image - 228.68 kB - 04/05/2021 at 07:51
Preview
Compatibility board scheme
JPEG Image - 65.13 kB - 04/05/2021 at 07:51
Preview
