I have analyzed and graphed the collected data logs. The data covers everything within a 300 electron-Watt radius of the device.
there were no aliens detected.
device correctly reads 0V when only humans are within the detector field.
12 spurving vanes: 6 real, 6 imaginary (not visible in the photos)
This is a fairly simple and straightforward implmentation of a Drake-Feynman Alien Detector.
wikipedia has most of the details:
After interference by the neighbor's cat, the herring needs to be replaced.
Going to try placing it within a sealed vessel below the panatronic fan this time
I found a surplus 17 pantagauss feynman spaculume on ebay. This should allow a detection range of nearly 237 Hertz-meters.
